Thanks Eliot. My boiler controls do have the high limit fan turnoff which kicks in at 212 degrees. I was thinking I might be able to tie into that circuit somehow with one of those RIB relays which could cut power to and open the Automag. However, since the high limit fan turnoff is set at the boiling point, I am a bit scared of what disaster might occur if the water was already boiling when the Automag opened the dump zone. I was thinking of something like 200 degrees, as you mentioned, as a good point to open the Automag. I like your idea about an aquastat on the outlet pipe to open the circuit.
I read a couple of old posts on the subject this morning:
Jim (Jebatty) suggested the following in an older 2008 post: "I added a surface aquastat to the boiler supply plumbing, connected the low voltage supply to the Automag to the aquastat, and set the aquastat at 210F. Now if at anytime the boiler overheats to 210F with power on, such as with pump failure, power is cut to the Automag and dump loop is activated. This does not affect the power failure activation of the Automag. "
In an October 2011 reply to Goosegunner on this subject you mentioned if using the draft fan circuit, "to pass FMEA you need a mechanical high limit aquastat in series with the draft fan motor". If I used Jim's idea, and went with a well-type aquastat not tied into the fan circuit, would that satisfy the FMEA. That way I wouldn't have to mess with the fan circuit at all. By the way what does FMEA stand for?
I am a little confused too, on what aquastat to get. I am assuming Jim used a SPST. I would think I think i want DPST aquastat, so if desired I could upgade to adding a parallel circ at a later date, as you recommended to Goosegunner. However you mentioned a DPDT Ranco to me so I'm confused on which type would work, or if DPST aquastats are even available for this use. There are so many aquastats on the PexSupply site,
http://www.pexsupply.com/Honeywell-Aquastats-294000 . Would you or anyone be kind enough to recommend a specific model on that site or elswhere? Hope I'm making sense here. I'm trying not to screw this up. That recent post with pictures of stihlwoody's garage burning scared me and I want to make everything safe as possible. Thanks so much.
