A fellow asked me if you could do this. I said no - would think poor draft, smoke in stove room. Can someone please explain the physics of this? Thanks, Doug
dougand3 said:A fellow asked me if you could do this. I said no - would think poor draft, smoke in stove room. Can someone please explain the physics of this? Thanks, Doug
VTZJ said:dougand3 said:A fellow asked me if you could do this. I said no - would think poor draft, smoke in stove room. Can someone please explain the physics of this? Thanks, Doug
I run 8" singlewall into 6" Metalbestos by means of an off-the-shelf reducer on my cellar stove. It works well with two minor problems. (1) Chimney can be a little hard to start when cold, but top down firestarting has solved this problem, and the chimney drafts very well when warmed up. (2) The stove, a Defiant copy, can be burned with front doors open like a fireplace, but that calls for big draft and the 6" pipe is not quite up to the task all the time -- I occasionally get a little smoking when I run the stove this way. Stove works fine otherwise, no smoking when loading or operating normally for heat, doors closed.
Physics? Flue gas velocity increases and pressure drops as the flue gasses move from 8" section through the reducer into the 6" section. Like putting your thumb over the end of the garden hose to make it spray further, water speeds up across this restriction, moving from an area of high pressure and low velocity (in the hose) to an area of low pressure and high velocity. Bournelli's principle if I recall correctly.
Prada said:Are you saying if you have a 6 inch you can go to an 8 inch and it's legal or not? Sorry I'm a slow learner at times. lol
