Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
When I close the door on my isle royale it seems that the primary air does not supply enough air to keep flames going when its slid wide open. Is there a way to check if its too tight or do I want it as tight as possible? Thanks
The door should be tight. If your having a draft problem I'd check that your primary isn't clogged with ash, check chimney for creasote build-up, and make sure your using dry wood. Have you had draft problems in the past or is this new? If it's an ongoing issue, it might be your set-up isn't producing the proper draft.
You only need it tight enough to squat the door gasket to give you a good seal.Just get it good n snug.No need crushing it so to speak.Put your finger on the gasket and push.You know now how much pressure will seal it.Just make sure you have to apply some decent pressure to the handle to close it,no need bending things.The air intake on these new stoves does seem to starve the stove but with a good draft they'll work fine.Leaving the door open a crack works wonders.Never leave the stove at this time though.Sparks jump a looooong ways.Usually 10 min's will be long enough most times.Do NOT use the ash pan door open to start the fire.It will heat the stove up too fast and crack your stove or stove glass.It's just a thing you can do but should NOT.You want to know why not? Check the price of stove parts and the charge of uninstalling,shipping and repairs and re installation because you just voided your warranty. Wish ya the best.Stay warm.
