This is my 9th year running this insert. It is a large hybrid fyre insert. I used to destroy cats and have since switched to steel. But, these cats do start plugging up on me after about 7-9 weeks.
I now have 2 cats so that I can do a quick swap and clean at my leisure. I have a 32 ish foot liner. I have painted five marking lines on the air adjustment. 5 lines is fully choked. I usually run the stove between 3 and 4. If I run it at 1 or 2, the flames will lick the cat. I made a metal mesh to protect the cat a bit. I think some of my issue might be that I get the fire going again at 6am and by 6.40 and back it down to line 4 and walk out the door. Maybe that is causing a build up. Maybe I gotta run less wood, but more air flow to clean it out. Any thoughts? You would think I would have this all figured out by now. I have learned to use steel cats and have also learned many people could never own this stove. Many people would not be able to swap cats every 2 months.
Please advise. Thanks.
