Hi all,
mid 1970s 2-story colonial. Basement is a poured concrete foundation and in many places has fiberglass batts stuck to the concrete with a vapor barrier facing the inside space.
When it's mid-winter and 25 degrees outside and I'm only running the wood burning stove (which is on the first floor), the basement stays a consistent ~65 degrees. In truth, it never get uncomfortably cold down there. It's ~35% humidity in the winter and a dehumidifier runs alot during the summer keeping it at 45%
I have access to about 15% of the un-finished basement walls which remain uninsulated. I'm considering putting up something like 1-1.5" thick XPS foam board on those walls but I have no idea if that's worth it: it's only what I have access to, the basement seems to hold itself to a good temperature in the winter and it's not like I'm trying to heat it moreso, and I don't even know if it'll be worth the effort.
The attic is R-38 between blown in cellulose and then batts laid down perpendicular. The walls of the house are r11 or r13. The house is going to be re-sided this summer at which time I'm going to have it foamboarded, tyvek'd, taped, & sealed....it MAY actually become too tight for airsealing but I think it'll just get close to that. And I'm going to be tearing out the garage drywall, attaching some thickening strips to the drywall, and re-insulating the walls with thicker batts and re-sealing it.
I'm just trying to figure out my last few places to improve the heat retention of my home
So - insulate those exposed walls of my basement or leave it be and save my money and time?
Joe
Joe
