Hello
Heat does rise but ducting makes a big difference! The original 6" ductwork I put in consisted of 2 registers, one in the kitchen and one in the hallway towards the living room area. The fan in the ductwork sure helps alot but I ended the ductwork 1.5 feet over the stove. I did not realize the convection fan in the pellet stove could really boost the heat upstairs if fully utilized!
Like a Hot Air Furnace the Temp at the registers is approx 120 Degrees F which feels warm to the human touch.
Therefore extending the ductwork 1.5 feet to cover 5 of the 10 heat exchager tubes makes an astounding difference. The heat coming out the register is now 130 Degrees instead of 80 Degrees with the heat feed rate at only 2 that is 2.46 lbs/hr !
That is over a 62% Improvement ! Bring on the cold weather tonight!!
After running on feed rate 2 for a while this afternoon the temp in the living room shot up to 74 Degrees F so I had to turn the stove down to Heat setting 1 which is 1.7 lbs/hr !! Heat setting 1 measures 116.5 Degrees out of the heat registers!!
See before and after pics below!
