I've got the option of getting the stove in this thread: https://www.hearth.com/talk/threads/69592/ for free from my dad. I also have a fireplace that I do not use in the dining room/entry way. Here are my questions. Assuming the measurements of the firebox will fit the insert, what do I need to do about the following? I have a damper - I'm assuming I would have to remove that as the stove would/should make that unreachable. I also have a chimney cap that closes (not sure what that's called) - has a chain that hangs down the chimney and allows me to close the top of the flue. I'm assuming I would need to remove that.
I'm not sure what the connection is on the stove as I haven't pulled it out yet, but if it is rectangular, is there any reason I can't let it simply draft up the chimney. I know that's how it's done now, but not sure if that is correct. Will I need a chimney cap? I'm just not sure how much cost I'm looking at getting into here and wanted to see if anyone could give me the steps (multiple I'm sure) that I'm not aware of.
Thanks!
Thanks!
