Jay,
Here is a helpful FAQ from Oregon chain:
(broken link removed)
Here is the part about sharpening: (broken link removed)
I learned on a smaller saw--that may be easier, to get the hang of it. Also, I'd go get a new file--they seem to "fill up" pretty quickly, and then work poorly.
Also, in case you didn't know this, the file cannot have curve to it's profile. IOW, many round files are fatter in the middle, than the ends. No good. You need a "straight" file, in the exact size, for your chain.
Eric,
I totally agree with you here:
Learn how to sharpen with a file, Jay, and you’ll be a lot better off in the long run.
I also feel that while the dedicated-chainsaw grinders create a sharp chain, they seem to take off more "meat" than might be necessary, especially compared to hand filing.
Also, where do you plug the grinder in, out in the woods? :shut:
I've only taught myself how to hand file in the past few years, but I get good results when using a filing guide and paying attention to the degree marks.
Having said that, the "big" saw I borrowed (a Homelite 360 "Professional,”, 19” bar, from the 1980's, I believe) is now "hooking" badly, to one side. It was cutting straight as an arrow the last time I used it and sharpened it, and used it some more.
Since it will still saw out big chips when it's hooking to one side, (meaning, at least one side is sharp? Actually, both sides are fairly sharp) I thought I could get away with just sharpening one side, to even it out. I had then planned to sharpen both sides, normally, the next time it got dull.
Well, when I did one side, it was even worse--obviously, I had chosen the wrong side.
I then did the other side side, and got it to a fairly neutral place.
But now I can’t remember which side I had to sharpen, to even it out. And it’s hooking again pretty badly, to the left.
However, I do remember that it seemed that to correct the hook, I had to sharpen the opposite side from which I would have thought logical. (I think, but am not sure, that to correct a left hook, I initially sharpened the right, on the theory that the right wasn’t “keeping up.” Whatever side I did, originally, as I said, was the wrong one.) LOL If I remember correctly, even though it was hooking left, I think that ulitmately, I had to sharpen the left side, to straighten it out. Again, that seems backwards to me.
I’ve read the FAQ on this, from Oregon chain, dealing specifically with “hooking” (as I call it) or cutting to one side: (broken link removed)
Now, when I got the saw, some of the teeth were filed at different angles than others—I’ve pretty much evened that out.
However, there is some variation in top plate length as well (though there is plenty of meat left on all of them). I didn’t caliper all of them, and count up which side is shortest, but the “shorty plates” seem fairly randomly distributed between left and right which, to my thinking, means that top plate variation is NOT causing my hooking.
The other variables mentioned in the Oregon text on this, above, do not seem to be in play, e.g., the guide bar is not worn, and I don’t think anyone has touched the “rakers” or depth guides, so they should all be equal length (though possibly equally too-long).
I didn’t really grind away at the top plates, though, to even them up, because although I know they're all supposed to be equal, I didn’t have the heart (or energy) to hand file so much good chain away. And again, the variation looks fairly-evenly distributed between left and right.
Instead, I tried sharpening just one side, to zero out the hook. Like I said, it pretty much worked, once I did the correct side.
So I have a question, for you or any other experienced hand filers:
Even though we know there’s more (potentially) involved in a hooking saw, than just one side being sharper than the other, if we assume for now, that that's what's causing
this hooking, then which side do I sharpen?
Say your saw is hooking to the left, as you stand behind the saw. Which side of the chain do you sharpen, to even it out?
(Let's assume we're still standing behind the saw when we refer to Left and Right, so we're all on the same page. IOW, don't give me Left and Right while you're facing the saw, mentally, to sharpen it. Stay behind the saw, where it's safer....)
Thanks, all.
Peter
