Hello!
I have an Englander PDV25 pellet stove and for the most part it is running fine. My question involves the burn rate settings.
Currently I have the stove set at 6-6-1 {per recommended settings from Englander tech} and it doesn't seem to be putting out as much heat as I was getting last year.
I had the same issue last year and I spoke with support. They walked me through a process of unplugging the stove, holding a certain key combination on the panel and then starting the stove. It set the burn rate and was much warmer.
The stove was unplugged over the summer so these settings were cleared before this fall. I should have thought to write down the key combination but I never did *sigh*
Anyone has any idea what this combination might be? Other suggestions or insights would also be appreciated
