I know some cover their piles with clear plastic and others with black plastic, but I'm wondering if there really is a difference between the two as far as trapping heat.
As we all know, black attracts heat so I would think the black plastic would trap more heat than the clear (milky) plastic. I had used black tarps to top cover the wood piles, and had seen temperatures reach above 160 degrees, and I vaguely remember seeing 185 degrees.. On the other hand, I read someplace that black reflects heat, and that the heat doesn't go deep enough into the wood pile.
What I'm thinking is this, use the 6 mil black plastic for the firewood kiln sort of thing instead of the clear unless the consensus is to use the 6 mil clear (milky) plastic. Plus, would the black break down quicker than the clear due to the UVA and UVB rays? Or would it last longer?
I've seen pictures where people had tried the clear shrink wrap where the tops deteriorated and left the piles unprotected for a little while, and the same for the clear plastic. If I remember correctly, I think it was over the course of 6 months.
With all of the rains we've had recently, a total of 21 inches over the last week and a half, I'm debating using the kiln method to keep my wood dry for the coming years, or at least until I build a firewood shed. One specifically for firewood and no other storage. I probably won't have time to build that type of shed for at least a year with my other to-do's so I'm exploring other options.
I know my firewood will dry back out, though a week and a half of constant rains and viewing the water just run off the covered tops and down the open sides really has me thinking of a better solution. I did completely cover my current seasons wood with plastic and will remove it Monday when the weather breaks. Then give it a few days and possibly stage it on the porch after I check the porch for structural integrity. (it's 1 and 2/3rds cord) I already have 1/3rd of a cord in the house.
So which should it be, 6 mil black, or 6 mil clear (milky) plastic? What is your opinion?
. I was being so careful to cover so I'd have dry wood and the holes just funneled the water into my wood and soaked it. The other benefit is the plywood top stabilizes the stacks so after seasoning/settling for 4+ years they never fall over.
