Cast Iron Boiler Stoves??
Rob From Wisconsin
531
East-Central Wisconsin
We currently have radiator heat in our house.
It would be nice if we could add the woodstove
to that circuit. Any manufacturers of fancy, cast-iron
type models??
Thanks,
Rob
Rob,
I was thinking of doing this too until I realized I didn't have the room where my stove is
in my basement.
There aren't very many options here in the US. The closest you will probably get is if you can find
a Tirolia 7ZH. These were Austrian made cook stoves that were imported in the late 70s and early
80s. Nice stoves, and with a backboiler setup for handling several radiators.
This sort of thing is pretty popular in Europe where houses are smaller so the heat loads aren't as
high. Here are a couple links. If you Google 'backboiler' you will get a ton of links to mostly UK firms
which sell these. I have listed a couple below.
heating radiators with wood stove layout
(broken link removed to http://www.naturalheating.co.uk/cast-iron-multifuel-stoves-with-backboilers-c-54.html)
This one, assuming the link is good and current looks like a good deal but shipping might not be possible
or cheap
(broken link removed to http://www.naturalheating.co.uk/aiden-cast-iron-stove-with-backboiler-10kw-room-15kw-wate-p-705.html)
Good luck
