This morning I did the early A M pot cleaning on the Little Prodigy and decided after is was back cooking along that I would measure the outlet air temp.
On the LOW (1) setting the air temp in front of the vent is 160F
The airflow is pretty low at this setting too.
The fan is rated at 150 CFM maximum free air and I would guess that on number 1 it is about half or less of that volume.
On high setting (5) the temp goes to near 200F
I never run the stove at that setting though.
Normally 1 is the sweet spot and on a cold night for the first hour, I my select 2
The stoves hopper is so small that I like to keep the feed rat low so it will make it through the night from 11 P M to about 9 A M without needing fuel.
One soap bucket of shells will fill the little creature chuck full.
The Advantage in number 1 blows a little cooler at the vent but delivers a lot more CFM of air.
Just some Numbers.
Snowy
Just some Numbers.
Snowy
