http://www.termoventiler.se/media/upload/Laddomat.swf
Wrong language but look at the pictures
Press play
Press play
Dave, only thing I heard was that the Lado runs out of pump cap. on larger boilers per Zenon. I use mine on a 32KW with no problems. They do the same thing & are tank chargers/boiler protectors. The Termovar LU seems to have more capacity & hopefully Chris can answer this better, RandyDaveBP said:Welcome back, Hansson.
If a picture is worth a thousand words, a video must be worth at least ten thousand.
The Laddomat 21 seems to perform the same functions as the Termovar Loading Unit. Is this true? Or does one have some advantage over the other?
Dave, They had these "different" looking Lado's on the UK websites for awhile. I have never seen them available here. As I remember my Lado just had a brass valve that opened or closed by pump pressure or gravity, no spring assist. I have not checked to see if my boiler is becomming a radiator after burnout & will do this, RandyDaveBP said:only thing I heard was that the Lado runs out of pump cap. on larger boilers
Just looking on their website for the first time in quite a while, they seem to have some newer larger designs for up to 120KW (nearly 400K BTU's).
Don't know if they are available here, though.
Laddomat uses a (spring loaded?) poppet valve gizmo to open the unit to flow-through when the circulator isn't running. Termovar uses a brass/rubber hinged flap over a hole about 1" dia. No idea which is more reliable. I assume the poppet in the Laddomat closes easily (gravity?) to stop reverse flow and keep the boiler from becoming a self-circulating radiator when the fire is out and the storage tank is full. (Not positive from the illustration what the spring is doing there). The rubber flap in the Termovar closes from its own weight so wouldn't take much reverse pressure to close it. Have you noticed your boiler supply line staying hot long after the fire is burned out completely?
P.S. while typing this I looked at another illustration on their website and see the poppet is just closed by its own weight. The spring is just there for assembly of the valve and seat into the casting, I guess.
http://www.termoventiler.se/media/upload/LM21-60_reservdelslista.pdf
