I tried resetting my 55 TRPAH (12/13) using the procedure for the 25 PVDC thinking it's the same control board and it reset to 1-1-1 and it's supposed to be 1-4-1. Can anyone give me instructions on how to get it back?
Thanks,
Al
Thanks. That worked. If I need to change the settings again for a different brand of pellets do I have to go thru all the shutting down and starting up procedures again?
All depends...you could just turn up the feed rate....sometimes where the pellets are longer than average (1"+) then you might need to change the LFF.....
I moved up from the 25 PDVC to the 55 TRPA for the larger hopper. I assumed that changing the factory settings was the same. When it defaulted to 1-1-1 and I couldn't change it, I paniced. Going below zero tonight. I really appreciate your fast reply.
Thanks again. You da Man!
