Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
Had a power outage and ever since the stove has low flame and low heat output. Anybody know what mode this stove should be in? It currently is set to mode A.
Bottom 3 numbers are 6-4-1.
read a post on the forum, same stove set to mode C. Trying that setting now so far seems better but with probally need to contact tech support. Seems evry time I lose power it reverts back to A mode
i just sent you a PM, set in mode C , power failures usually do not cause mode jumping but occasionally do, let me know how it does back in mode C
to set mode, unplug, replug push blower up and down arrows quickly and release, then adjust the mode using the heat range up or down arrows (you only have a bout 5 seconds after bring it up so if you do not get there in time unplug and repeat
