Anybody out there ever run into this problem before? I am running a 55 Rancher saw. About half way thru a tank of gas the oil hole in the bar becomes plugged with sawdust not allowing oil to get to the chain. I have tried a couple things.Removed bar and chain, Run saw at idle to make sure oil pump is working. Oil pours out at idle,not a lack of lube there. Next I opened up the holes in the bar a little(like my 455 Rancher has approx 3/16 hole) Still does not help. It acts like the drive teeth almost pulls dust into the top of the bar and packs the hole full not allowing oil to pass. I hope I am not the only person with this issue. Thanks in advance for any help..
