Our farm has a lot of walnut tops from logging that I have been burning for several years that are fairly easy pickings. Not as good as oak but it kept the house warm.
The farm also has a lot of box elder on it because of a stream running through it. Last fall a rather large boxelder fell across one of my paths so I cut out the section in my way and left the rest lay there because everyone considers it junk wood around my area. Is this thing worth cutting up for firewood? I have never burned the stuff so I was wondering how it compares to walnut. It is still solid yet as most is up in the air and super easy pickings. I don't know if I should leave it to rot or get after it. I did cut a 8" test round off the other day and it split easily and it didn't stink too bad. I am guessing there will be at least 1.5-2 cords or more there. This would be used for 2011/12 season BTW so drying time wouldn't be an issue.
It would save the walnut some so that I can burn more years without having to "waste" it during the shoulder season.
Has anyone burned both to give a comparison of burn time or heat? I know neither are "high" on the scale. My stove does have a large firebox and is a Cat so burn times are pretty good with walnut going 10+ hours easy.
