imacman said:Most stoves running normally (not during auto start-up) run at between 125-175 watts.
Kenny said:A few years ago, I took some measurements on my P61A
When starting up (ignitor is on and the auger is running), the draw was 372W.
When the ignitor stops, and the auger is running and the distribution fan is on lo, the power draw is 128W.
With the auger is running and the distribution fan is on med, the power draw is 136W.
With the auger is running and the distribution fan is on hi, the power draw is 152W.
Without the auger running and the distribution fan is on lo, the power draw is 93.6W. So the auger is drawing about 35W.
Finally, in shut down mode, the unit was drawing about 46.1W.
Cheers
Kenny
SmokeyTheBear said:Ah yes, but the next question is when the unit is off what does it draw?
j-takeman said:Ah phantom power draw. Another reason to unplug the stove during the non usage months. Good point SmokeyTheBear!
j-takeman said:Hey Kenny(how've you been LTNS).
Could you fill us in on how you go those numbers? IMNTK! Thanks
j-takeman said:SmokeyTheBear said:Ah yes, but the next question is when the unit is off what does it draw?
j-takeman said:Kenny said:A few years ago, I took some measurements on my P61A
With the auger is running and the distribution fan is on med, the power draw is 13.
Cheers
Kenny
ya but u 4got to count the pellets!briansol said:My power bill went up about $20 a month when i started using the stove.
Luckily, my oil bill went down $500 a month![]()
BLIMP said:ya but u 4got to count the pellets!briansol said:My power bill went up about $20 a month when i started using the stove.
