I am in the process of trenching 150' of 1.25" thermopex from my home to supply the infloor tubes in my 1200 sq/ft shop. My boiler is in my house in the attached garage. I think I would like to run glycol in the infloor for the shop. Should I place a flat plate heat exchanger in the basement where the thermopex comes through the wall or should I place the heat exchanger in the shop after the the thermopex enters the building. If I installed it in the basement I think I would need more glycol ,but I would be safe from freezing. In the shop I would need much less glycol and heat less water through a exchanger. Anyone have the coorect answer?
