I'm putting stone veneer over my brick fireplace and I'm having trouble getting them to stick. I put down a scratch coat and let it dry thoroughly. I'm using sakrete stone veneer mortar and no matter how I mix it, it dosen't seem to stick well. I've tried what I thought was too wet and too dry and all in between. I'm buttering the backs about 3/4th of an inch and pushing them on till mortar squeezes out and giving a little wiggle. I hold it on for a bit, then let go, but after a few minutes they fall off. Or when I try to put the next layer on the one underneath starts moving and I can tell it's not adhering. Im trying to put on ElDorado bluff stone in a drystack. I was told by a friend I can only go a foot or so at a time letting it dry so the weight of the stones above don't push down on the ones below. But shouldn't they stick by themselves without weighing down the ones under them? I know with regular grout techniques its recommended you start from the top. There's no way my stones would stick in the middle of a wall with nothing underneath them. Is that because there's only mortar on the back? Going a foot at a time and letting it dry doesn't seem realistic. Would a contractor sit and wait 2 hours for it to set up good before putting in another row? It would take forever. I've heard that using a latex bonding agent or thinset can help, but I figured the veneer specific mortar would be good enough. I'm beside myself trying to finish this project. Any advice would be greatly appreciated
! Thanks
