Hello
My friend is interested in a used St Croix York Insert pellet stove for his fireplace for approx $1500 in very good working order.
Any pros or cons or anything he should watch out for?
Found Specs here
http://www.pelletstovefires.com/st-croix-york.html
Heating Area 1,800 sq.ft.
Max. Heat Output 40,000 btu.
Min. Heat Output 10,500 btu. Zero with optional thermostat
Automatic Ignition Yes
Manual Ignition If needed
Hopper Capacity 40 lbs.
Burn time 33 hrs.
Fuel Type Wood pellets, 50% corn and wood pellets
Glass Air Wash Yes
Built in Blower Yes
Convection Blower Capacity 210 cfm.
Thermostat Compatible Yes, available as an option
E.P.A. Approved Yes
Emissions 0.7 gr./hr.
Efficiency 78%
Dimensions for the St Croix York Fireplace Insert
Dimensions Insert
Height 21.25 in.
Width 25 in.
Depth 10.5 in. onto hearth 16 in. into fireplace
Min. Fireplace Size
Height 19 in.
Width 24 in.
Depth 16 in
Insert Surround Dimensions 45 in. by 32 in
Weight 220 lbs.
Window Size 23 in. by 9.5 in.
Flue Vent Size 3 in.
Rear Vent Yes
Rear Vent Height 6.4 in.
Battery Backup No, See Stove Sentry
Surge Protector Recommended
Colours Black
Exhaust Temperature Sensor Yes
Low Draft Shutdown Yes
Construction Type Fabricated steel
Automatic Shutdown and Re-ignition Yes, with optional thermostat
Found Specs here
![shade smirk >> >>](/talk/styles/default/xenforo/smileys/shade_smirk.gif)
Burn time 33 hrs.
Glass Air Wash Yes
Built in Blower Yes
E.P.A. Approved Yes
Efficiency 78%
Dimensions Insert
Height 21.25 in.
Width 25 in.
Min. Fireplace Size
Height 19 in.
Width 24 in.
Depth 16 in
Weight 220 lbs.
Rear Vent Yes
Colours Black
