I've been having a hard time finding a 5.5" round Poly chimney brush for a titanium chimney. Anyone know where to buy this unusual size? Would it be feasable to buy a 6" brush and use wire cutters to snip 1/4 inch off the ends of the poly bristles?
polaris said:Titanium? I learn new stuff here all the time. If you don't mind me asking......... just how much is a titanium chimney per ft.?
316Ti
Another variation of 316 is available. This variation is 316Ti. Stainless steel 316Ti contains a small amount of titanium. Titanium content is typically only around 0.5%. The titanium atoms stabilize the structure of the 316 at temperatures over 800°C. This prevents carbide precipitation from the grain boundaries and protects the metal from corrosion. The main advantage of 316Ti is that it can be held at higher temperatures for a longer period without sensitization (precipitation) occurring. 316Ti retains physical and mechanical properties similar to standard grades of 316.
struggle said:cutting it down to size with side dikes.
I thought it was poor idea to use steel brushes on on ss chimneys to begin with.Pine Knot said:Short for Diaignal Cutting Pliers I think. My 6 inch S/S liner ended up a little oblong rather than round after installation which makes it diffucult to get a 6 inch wire brush through it. Do the poly brushes work easier?
Hogwildz said:Dykes are a hand tool that cuts wires. etc. Can be had at any local hardware store or box store.
Ignore the "click to enlarge".
struggle said:Hogwildz said:Dykes are a hand tool that cuts wires. etc. Can be had at any local hardware store or box store.
Thanks for covering that question for me Hog While I am at it you don't happen to have any towers laying around in pieces or some copper laying around from some work you might have done around your state in Pa. :vampire: Seems there is a radio tower missing in your state on the news I read.
Hogwildz said:Ok fuggers, here ya go...
struggle said:I bought a 6" poly brush and spent some time cutting it down to size with side dikes. It took some time but works fine. No way would a 6" brush worked for me.
