Greetings Hearth forum. I have been visiting this site for the past few years in preparation for a fireplace insert install. I was finally able to pull the trigger on a CW2500 insert that I picked up used locally. The owners manual calls for 6" chimney liner. I would like to install pre-insulated stainless steel liner due to the fact that my chimney is located on the east side of my house and exposed to the elements. However, with the 8x13 clay flue the actual inside dimension is ~6.75" and the insulated 6" liner is ~7.25" . I can fit a 5.5" pre-insulated liner, but I concerned about the performance of the smaller flue. Anyone out there have any experience running 5.5" vs 6"? Any notable changes?
I should also mention that my chimney is ~23' -11", and constructed of 8x13 clay flue liner and 21x8x16 chimney blocks.
