Hey guys
The wife isn't in the house so I gave it hell when I got home from work.
I lit my fire and got it going.
Without my bypass damper open, there's no way I can get my flue temperatures to 1000 degrees. It's just not happening. I think it could be a faulty reading though. I placed my thermometer quite high and after a 45 degree bend. My thermometer is about 24 vertical inches above my stove top, AFTER the first 45 degree bend. I even bought a new probe thermometer made by "imperial"
When I cork it with wood, I have some whicked secondaries on the go if I close my damper as tight as it goes. I am sure that just because my probe reads 400-500 degrees it's still a good temperature. And I can promise my stove top HAS to be "cured", the magnetic thermometer that I bought for the stove top indicates 950 degrees. It's H O T. It's not white or red, just really warm. BUt I presume those thermometers on stove tops (that were made for single wall stove pipes) keep aborbing heat, hence a high reading??
I will fire it up a few more times during the weekend to see if I can fix the smell for once and for all. Otherwise, I will be posting on this website to get input on a new Fn stove.
Andrew
Andrew
