smoke coming into room any ideas?
ebenezergb
2
selby uk
Hi All
We have just moved into a property with an open fire but have a problem. On certain days smoke seems to alternate between up the chimney and into the room. I assume that it's a weather problem.
I have had the chimney swept. I have the vent under the fire fully open and grate and ashpan is clean.
Is their any solution to this or equipment to add to solve this?
Many thanks for any assistance.
Ebenezer
Sounds like a negative pressure situation. Air from outside is trying to find its way in to equalize the pressure, and the easiest way in is the chimney. Many people suggest opening a window in the room with the stove/fireplace to see if this resolves the problem. Google "negative pressure" and see if you get some helpful ideas. Welcome to the forums.
Possible to raise the chimney? Possible to warm up the chimney before starting the fire? Does the chimney have a straight run or are there bends in it? How tall is the over all height?
Agree with the other posters, need a little more info.
Height of Chimney? Any bends/elbows, etc..
What happens if you warm the flue by taking some newspaper and lighting to get the draft going?
(My MIL is from Yorkshire I believe)
Welcome aboard
ebenezergb said:
Hi All
Ebenezer
Add a couple feet to the chimney
Many thanks to all replies.
I will try your suggestions.
We live in a bungalow, so I think the chimney hight will be about 20-25ft straight up.
Thanks again
