quick question about shutting down please
mtalea
351
Bristol, Connecticut
If one choses to shut down a pellet stove for the night. what is the proper procedure....So there isnt any smoke etc;
Thanks
The pellet master will smoke on shut down if
You do not have enough vertical draft
Door gasket bad
Ash pan gasket bad
ron d said:
my p61a shuts itself down when not calling for heat. never notice any smoke. i shut it off manually when i go to bed by turning the room temp dial to the off position. slowly goes out and blowers run untill cooled off i guess. no smoke i can see.
The titan will do the same, ie, the room blower runs until the stove is cool as long as you turn off the combustion switch.
I have unplugged the stove and it burns down to the top of the auger,
but I recall you saying your stove smokes pretty bad, That might indicate you have a back draft into your hopper. If that is the case you could set the hopper on fire. That is why it is important to keep your gaskets on all the doors in good working order.
If I recall correctly it can take a few hours for the stove to go completly cold.
