Hey guys. I have been looking around the board for months deciding what to get for a stove. We decided to get a Harman P61A.
It's been about 1 month since installation, and I am happy so far. However, I have run into a snag!
Problem:
Yesterday, we started getting that dredded squeal sound. No problem. I cleaned out any carbon in the burn pot. This didn't help. I ran the thing through a cycle quickly and figured
out that the noise was actually coming from the motor area. I popped the back open while it was running and it was coming from the wheel bearing that hits the feed door lever. It was rubbing past the metal from the metal bushing that the auger drive shaft goes through as it was moving around. I put a little grease on it, seems to be fine.
Fast forward to today. I put in a bag of Oakies this morning. Noticed quite a lot of saw dust and a few swollen pellets from moisture. I tried to pick out what I could.
My wife calls me and tells me the stove is off. She tries to start it up. Nothing will feed and the auger wont move.
I came home tonight and cleaned the whole thing out. I emptied the feed bin, vacuumed it out. Cleaned out the burn pot again. Slid the feed door open a bit and vacuum all of the pellets that were in the auger.
I also opened up the back to get to the side plate. There was quite a bit of saw dust and fines all packed in there so I vacuumed those out as well. AFter putting everything back together, I put it in stove mode and had the feed rate at 4. Nothing. All fans and blowers come on, no problem. The auger does nothing.
Ok, lets try test mode. The feed motor light came on, along with all the other lights. I dont believe I saw the combustion light go on.
What does this sound like guys?? Could I have blown an auger motor already!!?? because of a bunch of swollen pellets and some saw dust packed in there?? Some help would be much appreciated. My wife is second-guessing our purchase! Help!
jarred
Problem:
jarred
