Chris S said:" one zone under pumps" ? If your head requirements are different, and more than one zone is calling, the water will always take the easy route. Changing the circulator is not going to help this.
On multiple zone systems, we sometimes use multiple pumps to zone valve headers to ensure the proper flow where it is needed. Or, uou can also use balancing valves.
webie said:Chris S said:" one zone under pumps" ? If your head requirements are different, and more than one zone is calling, the water will always take the easy route. Changing the circulator is not going to help this.
In all actuality I have the opposite problem , This house's heating system was originally put in to be supported by a small wood boiler running at 160 degrees . Good for me now with storage ,but hard to control with boiler temps in the 180's . Last night with the tank charged and boiler out I ran on auto adapt on the alpha . I think its pumping to fast as this morning the top of my tank was at 151 and the bottom was at 144 , there seems to be only about a 15 degree change in return temp . The first trial on Saturday the pump has no problem supporting 4 of my zones running . It kinda pooped out when I kicked in the last zone for the basement that one took quite some time for the water to fully cycle . I am not to worried about this as its rare that I would have all 5 running at one time In most cases here there is only 0-3 running at a time . Tonight I am running on the slow speed setting so far it seems to be doing OK . The return temp seems to be about a 25 degree loss which works here , will see what my tank temps are in the morning . Oh and by the way I have 1200 gals of unpressurized storage and am running a 30% glycol . My only other thought to slow this down might be to use the IFC which I am not now .
webie said:Pat not sure how your radiant is set up but mine is a loop with a taco 007 circulating it . All the grundfos has to do is to inject hot water into this mixed loop . The loop I run at about 120 and it handles it that easily because it kinda sucks the hot water in as it displaces the cooler water its ejecting .
The sweet spot I have found for my system seems to be setting this thing on maintaining the low pressure setting , its like the in between of the slow speed and the auto adapt . this seems to be working well right now as any zone that calls for heat the pressure drop causes the pump to speed up to try to compensate .
webie said:Auto adapt works good . I don't care for it because I use unpressurized storage its moving the water just a bit to fast for my liking and my whole tank ends up cooling down . The pressure settings are pretty cool because as you have zone openings the pump tries to maintain the same pressure till the pump maxes out . This thing is so adjustable I just dont see why it wont work for you unless you have some really bad plumbing , then I would stick with individual zone pumps .
webie said:There is one other thing , This pump doesnt use much power to move water Most of the time its between 10 at idle to about 24 watts, i have to set it on high speed to get it to max at 45 watts .
This is really really wierd
On the pump its self its says min .05 amps and 5 watts max .65 amps and 45 watts .
Now isn't it (volts X amps = watts)
I have it pluged into a kilowatt and its reading what the pump says and it will draw .65 amps and 45 watts , How can this be ?
