HollowHill said:
Hi, I'm considering the purchase of a wood stove and have been reading over this excellent site; gleaning a lot of valuable info and realizing how much I don't know :red: One of the issues I'm confused on is - what is considered seasoned wood? Is it 6 months dried, 12 months dried, 24 months dried? How does the type of wood affect these guidelines? Does the stove it's going to burn in have any effect on it (cat vs. non-cat)? How, then, does a person get started with wood burning? Do you cut down some trees and wait 2 years? If you purchase wood, how can you tell if it's been seasoned long enough? Is there a better time of year to buy wood?
I've got a woodlot, not sure what kind of trees are on it. Since my husband is not interested in this endeavor, I'm on my own. Since I don't have the gear, knowledge or strength/dexterity to cut my own, I'm wondering if I could offer to go shares with someone who has the gear, etc, but not the woodlot - he gets a certain amount of what he cuts as do I. Does that happen? What type of arrangement is usually made?
Thanks.
Please allow me to welcome you to the forum.
You are to be commended for your thought about the fuel even before you get the stove. If more people did this there would be much less problems with wood burning.
You ask first about seasoning wood and have some very good answers already. Let me just add that seasoning of wood is much different depending upon the type of wood you have. If you burn white ash or black cherry, the seasoning time is very quick and can be done over one summer. If you burn red oak, it might very well take up to 3 years.
The second part of the seasoning process is how it is seasoned. First, it must be cut to firewood length (not 8' logs), then split (smaller splits season faster than larger splits) and then stacked (off the ground) where it will get the most benefit from Mother Nature's wind and sunshine. Wind is more important than sun but both is better.
First, we cut our wood during winter. That means there is the least amount of sap in the wood and you also won't bother any birds that might be nesting. During the early Spring we will then split the wood and stack it. We stack it on poles that were cut in the woods but you can also use something like landscape timbers, old RR ties or even old pallets. The main thing is to get the wood off the ground and to allow air circulation.
Stack the wood no more than 5' high or even shorter so you won't have problems with the wood piles falling over. They will shrink as the moisture evaporates. It is not uncommon for that pile to shrink by 6" or more during one summer.
We never cover our wood pile that first summer but will cover the tops only (never cover the sides) before snow flies. You can cover with tarps but they won't last long and if you don't keep the tarp from touching the wood, it will freeze on the wood and you will ruin the tarp when taking it off. You can lay poles on top of the wood and lay tarp over that. There are many other ways to cover wood. We like to use old galvanized roofing but even rubber roofing material works great.
How long will it take to season? That depends upon the wood, how small it is split and how much wind and sun it gets. Most can be ready the following fall but some wood will not be ready yet; wood like oaks which take 2-3 years.
Cutting wood on shares can work very well. Some do it with the cutter getting 2/3 and the seller getting 1/3. Doing this is fine but one definitely has to keep an eye on whoever is doing the cutting. It should not have to be this way but unfortunately many have a tendency to forget how much they have taken...
If cutting on shares it might be best for you to first have someone determine what type of wood you have and what is best to cut out of your wood before you find someone to cut on shares.
Having a cat vs non-cat stove makes little difference except with a cat stove you would have to leave the cat off longer if the wood is questionable lest you ruin the cat with wet wood. We have a cat stove and have no problems with it; in fact, we burn half the wood we used to.
If you are fortunate, you might be able to find a wood burner who might exchange some well seasoned wood for some green wood which would get you to burning right away.
Good luck to you and if you have more questions please do not hesitate to ask.
