4 Way wedge worth it?
I didn't know that existed but I think about something like that every time I roll the log for the second split.
For me, it seems pricey (frugal Yankee) but I am actually considering it now.
Wonder how it handles larger rounds?
Depends on the logs you're running. Small to medium stuff they can be handy but are a PITA if you get into some nasty or very large stuff. If everthing you split is under 18" diameter and fairly straight, it might work out well.
If you can slip it over single and remove when needed for large logs it is good.
On mine, I welded the 4 way on the top splitter and the bottom splitter is for the nasty stuff
Reactions: Boog
On mine (northstar) I havent taken the 4-way 'wings' off since I got them. Big improvement.
I really like mine, but on anything smaller than an 18" log it splits it unevenly. I think its 9" to the center.
I'd like to find a self centering device that would raise a log so that the center would be in line with the horizontal part of the wedge.
It all depends upon what you are splitting. In addition, I like to split so we end up with more rectangular pieces or square pieces. Sure is better for packing the stove on those long cold winter nights. Also makes building the ends of the wood stacks much easier.
Reactions: MasterMech
I have the slip-on style 4-way for my Timberwolf, and like it a lot. The height is offset, so just flip it over to set it at a different height. I always run it at the higher height so I can halve smaller rounds underneath the "wings". I do lift the end of pieces to center it on the 4-way. For big rounds I find I prefer the single wedge. Often I'll split a bunch with the 4-way, sorting as I go, and then split for a while without it. Nice to be able to run at double speed whenever possible.
Timberwolf and Iron & Oak both offer hydraulically adjustable height 4 ways for their machines. We're talking $6-7K splitters now. ::-)
I always used the 4-way on my TW2, and definitely recommend one. Cuts your splitting time in half. Additionally if you are splitting some big nasty rounds just take it off and halve them.
I'm with the others here that like their 4 ways . Makes for quicker processing as long as the wood is reasonably straight grained . Only takes a second to slip on ,or remove .
Have it coming in. Was $100, figure WTH, give it a try. 28 ton splitter so I'm sure it will be do just fine. My 12 ton did fine... as well as the 5 ton.
