Anyone use as their primary saw? I have only run one for 10 minutes after I sharpened the chain for the owner. That was over a year ago, but I think I am still smiling. I think I want one. Do I need it?
Jerhurt: where in VT are you? Is the 2172 your "primary saw"?
I agree there is nothing wrong with having all the toys...I cut trees and firewood. I might be looking for more reasons why not to get one.
The only saw I own is a 372xp, therefore it is my primary saw. I fell, limb, buck, cut, carry around, etc. I don't feel it is heavy, I can run continuously for hours on end. I usually take a break for fuel and a chain touchup.
Your signature says you have Stihl saws (I'm guessing more than one), and "many big toys".
Maybe I don't need a 395, but it sure is sweet running one.
I picked one up on a whim and have enjoyed it. For felling and bucking 18" and larger, it rocks well above the Stihl 029 that I've been using for 18 years. The size and weight of the 395xp for those two chores is not a problem to me. The 395xp cuts the trigger time almost in half compared to the Stihl 029. For limbing and such, I haven't even attempted with the 395xp and feel it to be too risky and honestly it's probably not the right tool for that. Another up side to the big ones is the ability to mill beams, planks and boards if needed.Anyone use as their primary saw? I have only run one for 10 minutes after I sharpened the chain for the owner. That was over a year ago, but I think I am still smiling. I think I want one. Do I need it?
I have run other smaller saws, mostly friends saws. Can't say as I could stand anything smaller than what I have for very long.
16 pounds isn't very much weight at all. When I can't lug that around I guess I will quit cutting wood. I know a 71 year old man that uses a 385xp to cut his firewood....
Yeah I have a 390XP too, a little smaller than the 395XP... I had my 390 ported by Scott Kunz AKA the tree monkey since he’s just down the road in Augusta Wisconsin like you did I think. I figure my ported 390 puts out around 9hp now but it’s heavy to me and I use it just when I need it for some big stuff. Otherwise I grab my ported 562XP with its 20" bar and full chisel chains. Vtwoodheater- If you cut big wood at times then go ahead and get one. You could get your 372XP ported and probably have rhe same power in a lighter saw too. I like ported saws, once you’ve run one your hooked.I have a 390XP and I couldn't imagine it being my only saw.Maybe I'm just a wimp though at 6'5" and 200-210lbs.
Yeah I have a 390XP too, a little smaller than the 395XP... I had my 390 ported by Scott Kunz AKA the tree monkey since he’s just down the road in Augusta Wisconsin like you did I think. I figure my ported 390 puts out around 9hp now but it’s heavy to me and I use it just when I need it for some big stuff. Otherwise I grab my ported 562XP with its 20" bar and full chisel chains. Vtwoodheater- If you cut big wood at times then go ahead and get one. You could get your 372XP ported and probably have to same power in a lighter saw too. I like ported saws, once you’ve run one your hooked.
