I have a chance to buy a non-running powerhead, 395xp. I'm thinking that this is worth it but was wondering if anyone has rebuilt these and what the worst case scenario would cost to fix it up.
Check the piston and cylinder first,then check the bottom end bearings.I have a chance to buy a non-running powerhead, 395xp. I'm thinking that this is worth it but was wondering if anyone has rebuilt these and what the worst case scenario would cost to fix it up.
If both of those are bad then you are talking lot's of money to repair,especially if you don't fix your own stuff.
Whats the story on the saw? They have a weak spot on the cases that if the chain gets thrown a few times without a chain catcher,it can take a chunk out of the case.
It's a big saw worth some money running.If it needs work the OEM parts are costly.
That's a big saw and a good price. Pull the muffler, check the piston, cylinder, and compression.
You can get a cylinder and piston kit off of ebay for about 70, so I'd say do it if it's in good cosmetic condition, and not a complete mess.
Can't you hone the cylinder and buy and oversided ring kit? This is a standard practice with 2 stroke motorcycles.For $70 dollars you will be getting a Off shore piston /cylinder.
With a big saw that is worth some money the only aftermarket piston that i would recommend is a Meteor.If the cylinder is bad then find a used OEM.If there is transfer on the cylinder it can be cleaned off,and reused so long as there aren't any deep groves in the plating.
90% of the kits on eBay aren't worth the shipping let alone the cost of the kit.
But if you don't plan on using the saw anything will work.If you are going to sell it after you get it running then let your conscience be your guide.
If there is piston/cylinder damage you have to find out why there is damage.You need to pressure and vacuum check it before you take it apart to find the issue.
If you slap on a new piston and cylinder and you have a bad seal you will destroy the new parts before you fill your truck with wood.
ahhhh...I did not realize they don't have a steel sleeve. That sucks.
You're talking to a mechanical engineer....I meant it sucks in this case.Hard-plated cylinders don't suck. It's what allows their high power-weight ratio while being air cooled and long service life with no honing/re-boring ever necessary. The hard plating transfers heat better than a sleeve, wears much longer than a sleeve or a bare cylinder and costs more to produce than either. It only sucks if you do something stupid and cause heat seizure. Run them properly and they will last through multiple sets of rings.
You're talking to a mechanical engineer....I meant it sucks in this case.![]()
OME chainsaw cylinders are plated with NicasilCan't you hone the cylinder and buy and oversided ring kit? This is a standard practice with 2 stroke motorcycles.
It is extremely hard and shouldn't be honed.There are no oversize rings available for OME parts.
If you do have aluminum transfer on the cylinder walls it can be removed.
One way is to use acid to remove the transfer, but if there is the smallest defect in the Nicasil it will start lifting it off the cylinder.
Another way is to use sandpaper and carefully sand off the aluminum.The Nicasil is hard enough to stand up against the sandpaper as long as you are careful.
Hi WoodyThat's only possible in a small subset of cylinder failures because, once aluminum begins transferring to the Nikasil, you are a gnats eyelash away from catastrophic failure. And with just minor aluminum transfer to the Nikasil, the saw would likely still run.
Hi Woody
Could you elaborate on that?I don't understand what you are saying about catastrophic failure.
Thanks
