insulating blanket
burnunit
12
East LI NY
osburn 2400 insert has an insulating blanket on top of the baffles and fire brick
2 questions regarding this
#1 does it 'clog' and if so can it be cleaned or does it need to be replaced
#2 is it needed for operation
thank you
Hey, where on Long Island? I did this for 15 years or so in Patchogue and Commack. Sadly the business I worked for closed shop within a year or so of me relocating. That blanket isnt really a filter that needs to be cleaned. You do want to make sure a lot of stuff doesnt build up on top of it, where it could slow down the passage of smoke. The smoke from your firebox is directed over the top of that blanket where the combustion is enhanced. They are easy to tear, so don't be messing around with it all the time. Yes, leave it in there, it is a working part of that stove design
thank you
Several manufacturers use this . . .
1) No clogging, but it doesn't hurt to clean off any fly ash annually or as needed . . . just be careful since they can tear easily.
2) Yup . . . pretty important for the correct and safe operation of the stove.
