We were having the roof torn down and sky lights replaced and I knew something was a miss with the chimney and we did not really know for sure until I started air hammering brick off. Chimney had precast stone installed without a water wicking system installed.
Water was penetrating the faux brick and going around the mortar areas and seeping behind allowing moisture to go behind the roof flashing. There was at present time no water damage to sheet etc but every spring it looked like someone spread gravel around the chimney from all the pieces of material popping off the chimney from the freeze thaw cycles it goes through over the past 25 years that it has been built.
A had a few contractors come over and look at it and all agreed there was no simple solution so I decided to knock off the precast stones and go from there. Siding became my choice as nova brick was very costly and it is my understanding it also readily absorbs a lot of water as well.
After the brick was off we wrapped the chimney in ice and water barrier but it still is set up so that the chimney will be able to breath still.
We think it looks much better than it did before. Also I decided to remove the outside access door to put wood into the area to the left of the upstairs fireplace (right side from the outside)as it was proving another place for water to in and we have not used it for years as it is much easier to grab wood off a trailer in the attached garage than to haul it around behind the house in the winter.
It took me three days to get the brick off and a couple to put the siding on.
