Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
Is any kind of thimble necessary if you're going through a cinderblock wall? If not, can you simply pass a length of pipe through an appropriately sized hole and seal with rockwool, etc...?
In short, yes. Need more info though, is this a liner installation? If so you could get away without it but if its just stovepipe to the wall, then definitely.
I beleive so. The good folks here have helped me out quite a bit. I have an insulated thimble going through a block foundation. When asking about sealing air gaps, they still recomended 2" or so of clearance, so insulation was a no no. That being said, you'll want something designed for going through the block.
If you go to youtube and search for chimney liner depot they have a video showing a liner install and one showing a liner termination. I believe they say as long as you're passing through a masonry wall into a liner a thimble is not required and they show either using 2100* high temp insulation or high temp cement to seal the gap.
2. For a noncombustible wall (concrete block or poured
foundation), cut a hole 3/16" greater in diameter than
the outside diameter of the chimney as per Table 4.
If I print the installation manual it should be good enough for the inspector correct?
