Thermostat help (pics)
Jfk4th
683
NY
Can't seem to figure out how to get this thermostat going, the manual is no help, shame on you Lopi.... :shut:
Here is my set up with pics
This is for my Lopi Berkshire BTW
Also I have the switch to turn on the stove in the "Off" position, I think that part is right when using a thermostat
Does it take while turn off the stove and turn on with a thermostat?
  • [Hearth.com] Thermostat help (pics)
It has a pilot
So what you are saying is disconnect from stove the red and white wire and connect it to the red and white from the digital thermostat I bought?
Looks like its hooked wrong on the valve (hard to tell in the pic). You want to be connected to the two marked TH and TH|TP. The TP should only have the thermopile connected.
Basically, connect to the same spots as the switch on the stove itself.
I am NFI gas certified :)
Glad I could help out.
Wood Heat Stoves said:
top and bottom terminal to connect.
i'm very suprised the lopi directions wern't enough, they are the most detailed manuals in the business!!
Well that is true most of the time, but in my manual there was nothing listed for thermostat install :shut: . Everything else is detailed in Lopi which is to be expected from such a great company. I guess there is a chance I may nave missed it but probably not
