I am trying to figure out how to heat a 1300 sq. ft. mountain (9,000 ft. above sea level!) home. It has a basement, half finished, half garage; 20X35 main level, half of which is open, and a half second story that is only open to below through the stairway.
The house is currently heated with electric strip heaters - the most expensive heat source known to man. There is no duct work, so a forced air furnace would be a problem. There is attractively price natural gas, however. Then there is the problem of space - there isn't any. Not one room of the house can accept even the smallest stove without basically eliminating that room from use.
Question: Could I install a vented, thermostatically controlled gas fireplace and achieve reasonable efficiency? Is there any other solution that occurs to anyone? I don't have to heat every room - we can retain the heat strips as a supplement. My idea was to to build an insulated chase on the main level to receive the fireplace so as to have the face of the fireplace flush with the interior wall of the open kitchen/dining room/living area which makes up half the main level. There are ceiling fans to assist air movement.
Mark
Mark
