I'd like to start off I have read a lot of threads on this forum and you guys have a lot of great information here.
So I started burning wood this year after buying a home and some land. I noticed winter was coming and I might as well use the fire place and woodstove insert. Well this has been a learning experience. I have a stupid question though. I had a lot of smoke bellowing out of the older sierra woodstove insert(can't find a model number on it, no manual, etc), along the sides where it mounts flush with the masonry fireplace, the other sides (furthest outside of the other side of the trim), door gasket blew the right side door, and it seems like a gasket from the left side door window glass pane is leaking too. I looked outside and there is still some smoke coming out of the chimney however it isn't like it used to be, rather slow and dark. I am going to try to find a chimney sweep ASAP and see what's going on. But I am assuming there is a restriction of airflow somewhere since the air is escaping where ever it can.
Anybody who likes riddles want throw some ideas out there?
Thanks,
Unseasoned
Thanks,
Unseasoned
