Howdy -
I cleaned my chimney yesterday for the first time since starting to burn this past fall. I was starting to get paranoid because I exhausted my supply of kiln dried wood earlier than I expected and started burning the other "not so well-seasoned" stuff. I was a bit surprised at how well the wood was burning. I figured I'd be struggling with it and not getting as much heat out of it. well, I cleaned the chimney yesterday - I have a through-the-wall setup with a metal bestos chimney. The cleanout is about 6 feet above the ground, so I cleaned it from the ground. Most of what came out was already in the plug - about 1 cup of "coffee grounds". I looked up the chimney with a flashlight, and most of the way up it was just very lightly coated with a light brown residue. Toward the top it was a bit thicker and darker. I ran the brush up and hardly anything came out until I got to the top, then really just a bit of fine soot fell out. I rapped the bottom of the cap a few times (REALLY glad I didn't knock the cap off, since I don't have a ladder and can think of few things I like to do less than walking around on an icy roof...). All in all, I was very pleased with the result.
I did have a question, though. My chimney is 6", so I bought the 6" wire brush. Is this how you would want to size it? They had a 7" brush, and I wondered if I should buy the slightly larger brush to get better contact with the wall. The box said using a too-large brush will not clean the chimney any better, and could get lodged in the chimney. So I went with the 6".
