I looked up the dollar bill test before heading home for lunch.   the new 30nc doesn't pass.......
on certain parts of the door it does pass the dollar bill test, but on the hinge side, I can pull the bill out, it has some resistance, but not a whole lot.
on the hinge side of the door I noticed that it has from what I've read the regular dense black gasket,
PLUS some flat gasket that is stuck on top of the round gasket (top being toward the stove) I have to imagine that it didn't pass an internal quality check of some sort and the fix was putting flat gasket over the top of the round gasket?????
I loaded it up anyway, and got a fire going... (btw, I quit putting wood in it last night at 10pm and there were still a few small hot coals in it at 12:30pm today) I got it heated up, about 600 degree single wall chimney temp and 550 stove top temp. Shut the door, and when I push the control lever ALL the way in you can definatley tell a difference it will almost choke out the flames. there just isn't much difference between full open, and half way open.
I'm not getting secondary burn for very long that I've noticed. usually a wall of secondarys for 2 to 4 minutes, then just a nice calm burn. you can definately see where the dog house is blowing air into the firebox, the coals glow bright red at that location and the flames are behind it....
so,,, second fire in, and it seems to be working.
I'll just have to look into the gasket. I think what I might do is the smoke test others have mentioned to see if it is actually drawing air in around the door.
