Hoping some of our resident chimney experts might chime in. I have been discussing this in the "what's in you stove" thread but guessing only the regulars there are seeing it. This is regarding our house in SE WI, not the cabin in the Northwoods. Stove is the 30NC (tube stove).
Wood is good. Mostly 16-17% on a warm fresh split. Have had a few slight sizzlers, but not many.
Problem - I feel like I lose too much draft on overnight burns as the flue temperature drops resulting in charcoal and smoked glass. Fully loaded for an overnight burn I usually have to get down to the air fully closed to keep it under control (flue temp under 900, stt about 650). During the cold windy snap I did hit a flue temp of 1000 for just a second. If I leave it closed I have few coals, half a stove full of charcoal, and smoked glass. If after it starts to settle down (about an hour fully shut) I open to 1/8 open I have half the stove full of half and half coals/charcoal in the morning and still a little dirty glass. If after the 1/8 open for half an hour to an hour I open to 1/4 open I have mostly coals in the morning. Thing is I have to start the overnight load so early to have time to get to 1/4 open that the house is getting cold by morning.
Solution? - I am considering making part of the horizontal run angled (see photo's). Stove top to center of horizontal is 42", center of vertical to center of liner is also about 42", insulated oval liner is 20'. Bottom vertical stovepipe is adjustable. 2 - 90 degree elbows adjusted to create 1 offset 90. If I adjust the bottom lower stovepipe down and add a short stub at the 'T' and attach one of the 90's on each end I can have most of the horizontal run at an angle (guessing 30ish degrees) and maintain clearance to combustibles.
Questions:
1. Do you think this will help my loss of draft as the flue cools and allow me to keep the air a little more closed on the long burns?
2. Will it make it harder to control when flue temps are up?
I theorize that the angled section won't affect draft much when the flue is hot, but should help the draft as it cools...?
![16744890724563948748217189010689.jpg 16744890724563948748217189010689.jpg](https://www.hearth.com/talk/data/attachments/308/308320-2941879852b3c718e5846f41031e5e78.jpg)
![16744891130656761004200661584370.jpg 16744891130656761004200661584370.jpg](https://www.hearth.com/talk/data/attachments/308/308321-18e56860ab71e16e62e19b47e8f9b713.jpg)
Questions:
