Dear all
I am new in this forum I have a 3 sided glass fireplace which has no damper or any control of air.
It just sucks air form bottom as primary air and I guess from top as secondary air.
I am attachking here a few picture and videos to describe my problem and if you have ideas or things that you recommend me to check.
So the problem is that sometimes it does fire good but put smoke inside home/room as you see in first video its looking that is burning well but its pushing smoke inside from top side of glass as in picture with red draw lines.
In the video where you see smoke from top sucking in bottom that is how I see smoke ( air coming inside as secondary air ? in this video is when it worked well that smoke you see moved faster so chimney sucked better all this air - now when I burn fire that smoke goes at slower speed so it reverses a bit backside through top then smoke comes inside home/room )
I have lost a lot of time with inspecting chimney flue line and other things but I strongly believe that now all issue is on this fireplace since its not professional with air dampers air control etc and the distance in top where you see the air getting sucked for fire its big more than a finger place so is it possible that its too wide open and smoke tries to find other path instead of just sucking air from there...I am thinking of putting rope there in top of glasses to make that path more sealed I am suspecting its too open and that is reason why smoke doesn't sucked outside chimney at faster speed etc ?
Do you have any ideas or things which I can test/try I am open to try anything just to see if there is improvement.
I am outside of US from Kosovo but I found this forum helpful in fireplace stoves etc so I wanted to hear from any of you for my problem.
![3 Sided Fireplace smoking 3 Sided Fireplace smoking](https://www.hearth.com/talk/data/attachments/318/318755-cabfacbb61c47cc695c435e53206dd4a.jpg)
![3 Sided Fireplace smoking 3 Sided Fireplace smoking](https://www.hearth.com/talk/data/attachments/318/318749-8e2bc94cd2e3319a2b2fc24ff344e0f9.jpg)
![3 Sided Fireplace smoking 3 Sided Fireplace smoking](https://www.hearth.com/talk/data/attachments/318/318752-abb97596d52e6765b55fb532e29d07b0.jpg)
![3 Sided Fireplace smoking 3 Sided Fireplace smoking](https://www.hearth.com/talk/data/attachments/318/318753-1620fdbbc8aba8461969feef77611d4e.jpg)
![3 Sided Fireplace smoking 3 Sided Fireplace smoking](https://www.hearth.com/talk/data/attachments/318/318754-7f076419b2ab94d3a26a530ed6c1d048.jpg)
