Ghettontheball said:use a tee instead of elbow so u can pop the cap & inspect & clean
pre epa stoves were tested with a 3' rise &3;' run as standard. that 6' of pipe accounted for 30% of the heat output from stove into room
DAKSY said:Once again, you're gonna hafta build a chase around the Class A in the other room to meet code...
Don't forget to put the Magic Heat thingie on your connector! 8-/
Edthedawg said:Daksy's jokin' with you, Deuce. Magic Heat = creosote-forming monster you donna wanna hava.
tutu_sue said:I asked the same question in an email to Simpson and was told 2 foot at most to the tee. To get around the roof soffit, we used two 30 degree elbows and a 12" section. If you look in the Durvent catalog there is an offset table if you need to get around something. That's what I used to figure it out.
tutu_sue said:I posted to this thread last night, but the post date is back in August due to server update.
