3 Firewood questions
1- Obviously we all like to keep our firewood covered to where none of it gets wet at all. I was curious about just the ends getting wet, obviously not as ideal is never getting wet but how significant is just ends getting wet? Maybe asked differently, what do you guys estimate the wood's water loss at the end versus along the long split sides? I don't obsess over it, whenever the inch or so that sticks out and gets wet it always dries quickly.
2- what have you guys found to be the best time to buck the wood with a chainsaw? Perhaps it varies between tree types but my tree types are oaks and maples if that helps you. Obviously you don't have a choice when you are falling the tree, and of course you try to keep it off the ground if you can't get to it right away. But beyond that, have you guys found a significant difference in the ease of cutting with a chainsaw (less work on a chainsaw) if it is green versus one-month-old versus one-year-old etc.
3-similar question to number two above regarding splitting. It seems to me that the easiest time to split the wood is as soon as possible when if it is green, followed by quite a bit later like about 1-2 years when they have plenty of natural cracks at the ends. I think that if I split (felled green) about months # 3-12 it seems to be harder compared to those other two time periods (ASAP or 1+2 years later). And obviously we all like to get stuff cut & split & stacked as soon as possible but I was just curious what you guys have found with regards to ease of splitting and ease of chainsaw'ing. I really don't like to let the splitting be any other time other than ASAP because the wood can rot/punk from the inside out or outside in depending on the tree type.
Thank you.
Thank you.
