Hi, everyone. I've found this forum very useful in the past, but this is my first post. I've recently been getting a nasty odor -- like metallic cigarette smoke -- off of my stove after I empty it of ashes. This situation perplexes me because I've been running the same stove in the same way for a few years, and the problem has only just emerged. Moreover, the smell only occurs right after I empty the ashes. It disappears after the stove reaches a good operating temperature and remains there for an hour or so, and it never occurs at any other time (for example, it does not occur if I start a fire when the stove is cold but has some ashes in the firebox).
Here are the particulars of my stove and chimney.
- Hearthstone Homestead
- Stove hearth-mounted in a brick fireplace and connected to circular stovepipe running the length of the chimney (and capped at the top of the chimney)
- Center chimney (our house is a saltbox) with good clearance above the chimney
- Chimney flue lined with clay tiles
- Stove installed by the local Hearthstone dealer
- Fireplace damper opening around the stovepipe sealed with fiberglass insulation
Now for my analysis of the problem to date. At first I thought it was just dust from the ash emptying that was burning off the stove or pipe (although I do take pains to minimize the dust when emptying, and vacuum during and afterwards). So I tried vacuuming the outside of the stove and pipe thoroughly after an emptying, then wiped them down with a damp cloth, but these measures didn't help.
Now I'm thinking that the problem might be related to paint degrading on the stovepipe or to the ash pan under the stove. The stovepipe's paint is flaking off in parts, and I've had to clean off loose paint on a few occasions. Could some loose paint be vaporizing to produce the smell? I'd appreciate people's thoughts here. This explanation doesn't seem convincing to me because I figure stovepipe paint is designed not to be volatile at normal operating temperatures (plus, why wouldn't it happen with every fire?), but it doesn't hurt to ask.
Then there's the ash pan. The pan is too small to be useful, so I normally just keep it closed. I replace the gasket on the pan every year because I've noticed it degrades pretty quickly. I last replaced it in September, which should mean it's still good (however, I'll double check that tomorrow morning). But it seems telling that the smell only crops up when the firebox is empty. There's a grate for the ash pan in the bottom of the firebox, and I wonder if somehow some detritus is being knocked through it when I shovel out ashes and is then burning off the pan or the pan's enclosure. Any thoughts?
I'll be very grateful for any and all advice. Thanks.
