I've been burning 24/7 for a few years now with my stove in the basement heating a 2 floor 2100 SF cape. Originally I was adding 3-4 normal size logs into the coals and trying to keep the stove temp around 350-400 during the cold winter months. It would take 3-4 hours to get the first floor up to 70 in the morning. Sometimes I would need to use the oil to assist.
This year I tried a few different things, one of which is burning short hotter fires (425-450) earlier in the season, still using 3-4 normal sized logs. That seemes to work pretty well, but it still would take a couple hours to heat the house up.
Over the last month, I have tried a new approach, cutting some logs in half with the chop saw. On a bed of coals, now I add 3 half length splits facing front to back rather than side to side. On top of those I add 2 regular splits across to make a criss cross pattern. With the damper in the same position, the temp of the stove shoots up to 500-575 in no time. I get a good 45 minutes of over 500F with secondary burn before it all turns to coal and the temp drops to 350-400 for another hour. The house heats up faster without ANY oil assistance. I know I am using less wood doing it this way, at least I use less wood. My wife figured this out and on the days I am not home, she gets the first floor up to 78 by dinner time when I come home, too damn hot! Anyway, the house is warmer, and the first floor never went below 65 during the 3 day power outage last week. Also, I have used the boiler for hot water only, no heat.
Hotter fire is more efficient for sure.
