Pellet pile up
LuAnnM
7
Northern NY
Another newbie that needs your help. I have an Avalon Astoria pellet stove, on a thermostat.
Worked great until the weather turned really cold this week, now the pellets are piling up
in the burn pot. I clean weekly, not sure what else to do. I run off thermostat with stove set
on automatic, heat ouput med, with my restrictor at 1.5.
Hey LuAnn, and welcome to the site.
I have the same stove. I am also running on a stat, and right now I am 1st yellow light on heat setting, and on the line to the right of the #2 on the air restrictor.....no problems with pellets building up (burning NEWP right now).
I check my burn pot daily. I will try opening the air flow to the setting that Pyro is running at.. maybe that will help.
I will let you know.
thanks guys!
LuAnn,
also, what brand pellets are you burning? What year is your stove?
As far as adjusting the air, I do just what the owners manual says.....open it just enough that the fire is active, but the burning pellets are not "jumping" out of the burn pot.
Pyro, Pellet Stove is 2007. I am burning local made pellets., They come highly recomended by my stove installer and local neighbors who burn. Made by Associated Harvest in LaFargeville NY.
Since I opened my air flow to 2 the stove has not piled up and seems to be burning much better.
Thanks for your help.
Glad to hear you got the pellet piling issue fixed. The Travis stoves we have a pretty simple to operate. Now that you have it running decent, try moving the air control a little.....more air if you go to a higher heat setting, and vice-versa for lower heat setting.
Personally, I have only had my air control between 1 1/2 and 2 1/2 for any heat setting, but again, pay attention to the pellets...just enough air so they move a little in the burn pot, but whole burning pellets are NOT jumping out.
those are the pellets I burn. Best one I found around here..
