Troy-bilt 7550/13500 and transfer switch question
mralias
1,119
MA
I have a troy-bilt 7550 running watts and 13500 starting. I wanted to put the following transfer switch with this unit but was concerned if it would work due to the information noted below. Specifically, it says "Compatible with 120/240 Volt, 30 amp generator output, typically 7,500 watt generator". Will the transfer switch safely work with this generator or should I seek a higher rated transfer switch. Thanks.
Compatible with 120/240 Volt, 30 amp generator output, typically 7,500 watt generators. Kit includes the transfer switch, a 30 amp, 20 foot power cord set, an optional 20 amp male cord cap end and a Flush Mount Kit. Instructional Installation videotape included!
For Use with 120/240 Volt, 30 Amp Generator Output, Typically 7,500 Watt Generators
10 Circuits
Kit Includes Power Cord Set and Flush Cover Trim
Pre-Wired for Easy Installation
MFG Brand Name : Connecticut Electric
MFG Model # : EGS107501KIT
MFG Part # : EGS107501KIT
Sounds like its perfect!
Ditto; good match. Starting watts isn't sustained long enough to worry about.
Chris
Thanks guys....I will give it a go.
You probably have your heart set on a transfer switch, but I've installed this: (broken link removed)
Full link: (broken link removed) Distribution/Load Centers/Accessories, Homeline (HOM, LK, PK, QOM)/1100HO0301.pdf
Very cost effective.
