Hi all,
I finally replaced the gaskets on my IR. First real burn started this morning. I used a quarter of a Super Cedar free sample, and filled the firebox to probably 1/3 capacity, right in the center, North/South. I used full air, let it get good draft going, and cut it to half. Still kept burning strong. I jumped in the shower for 20-30 minutes, came down and checked. Stove had taken off just fine, and it was at about 650 stovetop temp and rising. I cut back the air to about 1/4, and temps kept going up. I closed it off to *almost* 100% closed, and the temp kept rising. I finally fully closed it, and the fire started to die and smolder. Is there some kind of "sweet spot" that I'm just not hitting with the air control, or what?
On a side note, with brand new door gaskets, it takes a decent amount of force to get the door closed, but the dollar bill still slides on the DBT. Granted, there is far more resistance on the bill now, but it's far from impossible to slide it out. I also noticed my air leak problem previously was more than likely due to the fact that one of the glass gasket seals wasn't seated at all. There was a 1/4 inch wide, 3 inch long gap that air could pass right through. That has been fixed.
