Help - Whitfield Shut down after 5 hours of operation
Iceshack
9
Northern Canada
I've owned a Whitfield Advantage 3 since 1993 and with regular maintenance have enjoyed hassle free heat for that time. last year I had to replace the auger motor with a new one and the front glass is cracked a bit but otherwise - awesome experience with it....until yesterday.
After 5 hours of continuous operation the stove just quit - both fans and the auger! The stove was quite hot still and there was still hot ash in the grate. We checked the breaker and the plug outlet, let the stove cool down and thouroghly cleaned it and the exhasut pipe. It will not restart.
I called the closest pellet stove place (who don't deal in Whitfield) and was told that its a fuse. Do these things have fuses? Can I tell if the High limit switch is defective somehow? Where is the high limit switch? Is there a button on the switch that pops out iif it overheats and I just press it back in.
Any help appreciated
Thanks!
Will check all electrical connections and then "attempt" (not the most electrically inclined person) to check operation of the high limit switch and blower fan, consistent with info on the link you sent.
I'll be sure to unplug before foolin with it,
Your response appreciated!
